I am the proud owner of a 2003 Ztech ford focus. It came to me with 106K miles. It drove very very rough, so I did the motor mounts, which brought to light a rough idle and low power, which I somehow couldn't perceive through all the rattling. Spark plug 4, when pulled, yields no change in the motor's rhythm. I replaced all spark plugs, the discoloration in plug 4's core-nose insulator is very un-even, all of the plugs have black/grey coloration, not tan/brown and not at all gunky. Nothing oily comes off on my fingers when I wipe the tang of the old plugs.
Since replacing the plugs, I stall even more easily and the idle is actually worse. Cylinder 4 still is not firing. They came from the factory with a gap of .050 - .055" which I'm told is usually OK, but the old plugs that I believe came from the mfg were a step tighter, .044 up to .05.
I applied a volt tester to plug wire #4 with regards to continuity, it seems normal or better relative to its brothers.
Since changing the plugs, I get a sulfur smell in the cab. Does a mis-adjusted gap effect the way the fuel burns, and could the preset gaps be a contributing factor to this sulfur smell? There was no funny smell before doing the plugs, but I did have the power issue and the arrhythmia. . The check engine light is not coming on through all this. I haven't had a problem that causes the light to come on (Except stalling), so I dont know if the diagnostic actually works.
Thank you for merely reading all this. Sorry for the long post. I am not familiar with etiquette on this board. I'm doing all of my own everything on this car, I don't have a mechanic that I trust in this city. No disrespect intended to any professionals here.
