Sign Up! To view all forums and unlock additional cool features
Hi have a mk3 focus headlights not working not bulbs tried bulbs but instantly blows fuse in glovebox..spots and low beams work fine just heads..any ideas what can be wrong ? Thanks
If it instantly blows fuses, you have a short circuit somewhere. If they blow with the switch off, the short is on the "hot" side. If with the switch on, short is after switch and before lights. Check for bare wires touching any metal ground. Also check all connectors to see that one didn't fall off making a direct connection to ground, or that it got bent/damaged.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
