- Toledo
- OH
- United States
- 2009 Focus SE (gf's car)
New guy here. Sorry for the lack of intro. I'm at work.
My ex g/f called me as the brakes on her 09 Focus SE failed.
I assumed she'd ran the pads into the rotor, but the fronts still had plenty of meat on them. (at least 50%).
The fluid was a murky gray, the pedal has very little authority-- and slowly goes to the floor. Hoping that she'd cut a line, or maybe one had rusted I had her come out and push down the pedal.
IT bubbled (air) into the brake fluid reservoir. I assume failed brake master cylinder, but I've never seen one blow air into the reservoir.
I tried briefly to bleed the fronts, but the bubbling continued as I made attempts to do this on the fronts (Yeah, I realize you'd start from the passenger rear-- but I think the problem is the MC, not air in the lines).
Is there anything special I need to know about replacing the master cylinder, or any tips from someone who's done one on this? Looks like it should be pretty easy to get at, once the battery, and maybe that fuse box are out of the way.
Thanks in advance
AJ
Thanks in advance
AJ
