I'm having an issue I can't seem to figure out. After driving for approx 25 min, the car loses all power. I step on the gas and it barely moves. the only thing I can do is let it sit for several hours (or overnight) then i can drive normally again (for another 25 min or so). It seems that after the car cools down, it drives ok. the car is not overheating and the clutch was replaced less than 1 yr ago. I've checked for loose or missing vacuum hoses but found nothing. i recently replaced the PCV valve and rubber elbow hose connected to it because I have a check engine light with a code that pointed to the PCV valve (can't remember the code) but that made no difference. I do have a pretty good oil leak from the valve cover that i will be taking care of after work today, but i'm not sure if that has anything to do with the extreme power loss.
2001 Focus ZX3 ZTech engine
thanks in advance for any advice.
