2004 stalls at idle
cdyoung
2004 Ford Focus
New to forum have 2004 SE with about 100K. Engine runs well. Will stall with any prolonged. Idling either in drive or nuetral. Cleaned idle solenoid wasn't that dirty, replaced map sensor, cleaned throttle plate, plugs look good. Battery is on scan code but installed battery charger while idling with no help. Needs an 92 sensor, but could that effect idle. Changed fuel filter also. Thanks for any help
MKVIIST
Senior Member
AZ
o2 sensors are cheap and fairly easy to replace if you haven't already done so.
